Grit_dog
Dec 12, 2020Trailblazer
theoldwizard1 wrote:Metzfamily wrote:
We tow with a 2020 Chevrolet 1500 Silverado that has a 3.23 rear ratio and a towing package with built in sway control.
You did not mention the engine size or the transmission !
A 3.23 rear ratio is simply the wrong ratio ! Minimum of a 3.73. Withe the CORRECT engine, transmission, rear axle and load package a 1/2 ton should pull that trailer fine.
Old whiz, you can’t even get a 3.73 in their truck model. So, ill advised there.
