Gdetrailer
Dec 19, 2020Explorer III
Metzfamily wrote:
I still don’t know how to post a picture on this forum or I would post one is a nice looking truck though
This forum does not "host" pictures, you need to use an external online host that can provide a shareable online link.
One of our RV.net members setup a real nice host for this purpose..
HERE
All you have to do is drop your photo onto that app in the link, once it is done uploading to the host you will find a text box under the pix in the ap..
Copy the entire text in that box, it contains everything you need to make this work..
With that text you copied you can directly paste the entire text into your post..
If you use some other host means you will have to use the "advanced posting section" which you will see extra editing options in Icons above your message.. Choose the one that looks like a yellow icon with a mountain and sun. In there you will need to past your URL and manually set the pix to a width to no more than 600 High and 400 Wide (wider than that and everyone will have to scroll side to side and up and down to see your pix).
If you use the "ap" provided by our RV.net member, the sizing is already done.
Hint, if you have something that you may want to post again, you can save that URL into a text document on your PC.. I keep a few text documents with picture links and descriptions so I can easily repost if needed.
