Airstreamer67 wrote:
The Crown Vic should be a great tow car. The biggest problem is the manufacturer's specifications. If you are ever in an accident that is later contested, you can expect anything you did beyond what the manufacturer specified to be a problem to your case.
I have often wondered what protection I would have in an accident (my fault) if I was under the ratings. Does the % under the tow rating that I am towing reduce my liability by a proportional amount? What if I am not towing anything and I get in an accident? Is there 2000 lbs less liability?
Thanks!
Jeremiah
