ScottG
Jul 10, 2018Nomad
The sensors don't generally have issues and if it came on and went back out for the rest of the drive, it was probably too hot.
At a minimum you need to install the biggest trans cooler (probably the second one) you can find if it will fit and I would add a gauge to it as well.
Dont let the trans "hunt" or shift back and forth between gears. That causes excessive heat - it's also a sign you need more power. If it does hunt, shift to the next lower gear and leave it there.
44,068 PostsLatest Activity: Jun 01, 2026
