travelrider73's avatar
Nov 16, 2013
Towing in the Rockies - Towing Capacity Safety Margin?
I'm researching both a tow vehicle and a 5er combo and want to make sure that whatever we end up with as a tow vehicle will do the job no matter where we travel. The steepest grades I can think of are in the Rockies, hence the title of this topic.
So, how much of a safety margin between the manufacturer's stated towing capacity and what you actually purchase would you want to have in order to be comfortable with occasional steep grades?
Note that we are not planning to full time in the Rockies, and we will certainly spend some time on flat land, but I don't want to be climbing at 10mph up-hill and out of control downhill when we run into these steep grades. So, I guess we'll need a real jake brake too.
2013 Ford F350 Crew Cab Dually 4x4 - 23,200 5er towing capacity. How much GVWR trailer would you actually be comfortable towing in steep grades? Would you be ok with a 19,000lb GVWR trailer?
2013 Dodge RAM 3500 Crew Cab Dually 4x4 - 28,900 5er towing capacity. Would THIS be enough for the 19,000lb GVWR trailer?
These are just examples. I haven't actually picked a 19000lb 5er yet. The question really is - how much safety margin should I have?
I'm also NOT going to end up driving a big semi tractor. We want a normal pickup to be a daily driver when we're parked and a 1 ton dually is about as big as we want to deal with.
If we have to compromise, it'll probably be on buying a somewhat lighter 5er.
Thanks!!!
