rexlion
Dec 06, 2014Explorer
I see two problems. One, the dry hitch weight is nearly 400 lb and once you get loaded it will probably be 500 lb or more. Check the hitch weight rating of the Pilot, you may be over. Second, your trailer has a large frontal area (8' wide) and will push a lot of air; you could do ok if you keep your speed down around 55, but beyond that it might struggle and do a lot of shifting (which is hard on a transmission). Weightwise you are within the limit and have plenty of cushion. So the first thing to check is the hitch weight rating, and if it's ok and if you are comfortable with a slower pace, then you could get it.
Personally, for that trailer I'd lean more toward a Lexus GX460 which has a V8, or a V8 or diesel Jeep Grand Cherokee/Dodge Durango.
