Milkman670 wrote:
This is from another thread " My Creek has a listed GVWR of 13,750 and I typically travel at 13,350 pounds. And my pin weight is 3000 pounds"
The trailer I bought last fall was so far out from the listed weight it was stupid. I prefer 20-25% pin weight, as for length just plan turns a little wider.
And that would present a problem for the trailer in question here.
15% used to be about the normal for pin weight, but then again, that was back in 2005 or so. Things have changed a lot since then.
20% would probably be better.
Well, I can only hope that advertised was correct in this case. If true, the trailer in question will work with the pickup mentioned here.
