Bluedeacon wrote:
We have a 2021 Wolfpup 16fq, 3200 lbs, nearly 12' high if you include the AC; figure 4000 max with us and fuel and gear.
I think your estimate is low. Fully loaded I'll bet you are around 5,000.
Bluedeacon wrote:
I wonder if front wheel drive - like the Flex (4500lb tow) or the Traverse (5500lb tow) are up to the task.
Years ago, I had a bad experience towing with a FWD Taurus. I vowed to never tow with FWD again !
If you go with AWD for either of those vehicles, additional maintenance on the transmission and AWD unit I highly recommended.
The EcoBoost Flex can get thristy. Best way to save fuel is drive between 60-65.
