4x4crazy's avatar
4x4crazy
Towing mods with cabover
I have still been tempted to get a cabover although the bang for the buck from trailers is tempting me. I like that I can tow my boat with the cabover. I have a 2017 Ford F-250 short bed and I was looking at a used Lance mide 2000's 825 and a few others like the 845 or 815 or an older Eagle cap 850. there seems to be several levels of modifications to tow. So, I am trying to figure out what I am going to need to do to tow my boat. I am going to say my boat and trailer is around 5000lbs. Its a Sanger V215 if anyone is familiar. List weight for the boat is 3100lbs, plus the trailer of about 1000-1500lbs, plus gear and gas. Most of the cabovers I have been looking at don't have a ton of overhang. The Lance 826 has a 8'6" floor and the 845 has an 8'11" floor I believe. My bed is 6'9" long. I think my boat has more than enough tongue distance that I don't need to extent the entire length added. Any input? Also, would you just lower the tailgate with those campers in place or take it off?
  • My 6.75' short bed Ford required a 28" hitch extension to clear my Arctic Fox 811. I did not need to add blocking between the truck bed and camper to clear the tail lights or forward lip of the truck bed, but each camper is different. Mine had generator exhaust and sewer drain hanging from the rear wings that would interfere with the trailer tongue if it tried to occupy the same space.
  • You spoke of trailer tongue distance. Keep in mind; when you go over driveway entrances, like at a gas station, the truck with camper will dip the back end while the boat will be still 'UP' on the street. This could cause an interference issue between the bottom of the camper and the top of the trailer's tongue that's up under the camper.
    Try to plan what ever length hitch extension you will need so the ball is just past the rear of the camper. That is for two reasons; the first I just explained, but if it's close to the rear, the trailer tongue probably won't interfere. The second reason is that the ball height, in order to keep the trailer parallel to the ground. level as they say, might not allow enough clearance between the top of the ball and the bottom of the camper for you to hitch up the trailer. At least, not without using the jacks to lift the camper to gain the clearance needed.
    Just something to think about.
    If you do use an extension, I highly recommend using chains with turnbuckles so you can tighten up the extension. That little movement at the receiver is amplified from a little wiggle to a few inches when it's projected 2 or 3 feet out. Add to that, the ball mount will also have wiggle. Without tensioned chains to stake out the extension, you will get so much movement, that again, if the ball is under the camper, it could hit.
    BTW, I'm over in Placerville, about an hour from Rocklin. I have a short bed Dodge with a Lance 855S 8'11" camper and I flat tow a Suzuki Samurai 4x4 behind it. I'd be happy to have you come over and see how I set up my tow extension, my safety chains, lighting, trailer brakes, etc so you get an idea of what all you'll need to set up towing with a camper on. Lots of little parts like receiver pins, wiring extensions, various clearances, etc are all details that took me several trips to work out. I spent several afternoons with the camper, the truck and the towed working out the angles, the leverages, the wiring, etc. I'd be happy to pass what I learned along over a beer or two. BTW, got a couple other camper guys who tow as well living very close by and I'm sure they'd be happy to drink beer and pass along their combined knowledge as well!
    Torklift Superhitch and Supertruss
  • You don't necessarily need any hitch extension. I towed lots of different boats behind several different truck/camper combos (all campers longer than the truck bed) without extensions.
    Boat trailers tend to have a generous tongue length already, and the pointy bow doesn't cause clearance issues as much as a square box trailer.
    The listed dry wight is fantasy-land, in the real world campers always weigh more.
    Your truck can handle this easily, regardless of what the stupid rating sticker says, but you may want to get some overloads of your choice.
    I like airbags because of the infinite adjustability.
    Many here like the blocks that make your factory overload springs contact sooner. Those are inexpensive and work well too.
