owenssailor
Jan 24, 2016Explorer
Once your WD hitch is set for the proper weight transfer and the trailer is level to slightly nose down make sure all your tires are aired up. The trailer to max. The rear truck tires to max (if P tires) and the fronts I find work well about 4 PSI below the rears.
With the Equal-i-zer hitch I find very little to no movement.
Good luck.
Good luck.
