rfloyd99's avatar
rfloyd99
Towing "movement" - How much is normal?
I took delivery of my first TT on Friday. It is a Jay Feather (Jayco) 26' OA which weighs 4837 dry, per the door sticker. I upgraded to the proper size (I called the techs at the factory) Equalizer W/D hitch. The guy who installed it at the dealership seemed very quality conscious, but I definitely plan to double check the installation.
I drove the rig home, about 25 miles, of which about ten were interstate hwy. Seemed okay, but remember I only have experience pulling my boat, which weighs about 2800-3500 lbs (guesstimate). The boat tows very stable, no sway or other "squirrelly" movement. It is a 19 ft, fairly low profile fishing boat.
I drove a range of speeds from 55 - 65 MPH. The day wasn't really windy, and it didn't seem to sway when I was passed by a few semi's. The road surface in general is quite good where I was.
My question: There seemed to be a lot of random "movement". I hesitate to call it sway, it just seemed to be kind of "alive" back there - a little more than I was expecting. TV is a 2012 Ram 1500 with the large V8. Power was not a problem, and the weight, even with an additional 800 -1000# seems well within the towing limits.
I know this is a very subjective point, but does this seem normal?
Next weekend I'm going on a 60 mile RT (half on the interstate). Any tips or ideas on what to look for or to expect would be appreciated. We plan to put quite a few miles on this rig over the next couple of years, and I definitely want to get this dialed in to have the best possible towing experience.
Thoughts?
  • To better compare your boat trailer to your new TT, measure the tounge to axel distance. I wouldn't be suprised if the boat trailer distance to the axle was greater, this would make it sway less and the CG is also lower.
  • Load up truck & trailer camp ready....you, fuel, passengers, backpacks, stuff, everuthing in trailer for trip....and go to scales and get your weights
    Truck & trailer WITH WDH hooked up
    Truck & Trailer WITHOUT WDH hooked up
    Truck alone
    Then you will have all the numbers so you can set up trailer WDH properly
    Otherwise you are just guessing........can get close using measurements but weighing gets you the numbers.
