jhill7 wrote:
I did verify the dealers were not trying to low ball me with the "dry" weight as stock. All the weights I have received as with all options. But again, I don't think the problem is the tow capacity but rather the payload.
You are missing the point on trailer weight! Assume for a minute that 6900 is the as-delivered, all-in weight. The average family adds 1000-1500 lbs of "stuff" to their trailer when it's packed for camping. Things like clothes, pots/pans, dishes/glasses, towels, toys, appliances, etc etc. So that 6900 lb trailer will likely weigh around 8000 lbs WITH THE TANKS EMPTY!
Since you have already pulled the trigger on this and can't afford a new truck, here's what you can do to your current truck:
1. Replace the P-rated tires with LT tires, load range E.
2. Replace rear axle fluid with synthetic and add a finned hi capacity cover.
3. Add a transmission cooler and temp gauge. Switch fluid to synthetic and consider a shift kit.
4. Add airbags or overload springs.
5. Add HD shocks.
OR:
Trade your truck for a 2500 model that may be a year or two older. Even trade no cash needed.
I know you think it can be done, but trust me I have been there like so many others, thinking that a better towing experience is just one "upgrade" away. The NEXT trip will be better....guess what....it never happens, and after wasting $$$ on upgrades you will finally come to the realization that you need a 2500.
We welcome you as a new member, but would have been great if you would have joined before you pulled the trigger on this camper.
