parker_rowe
Apr 14, 2019Explorer
p220sigman wrote:
The short answer is it depends on the Pup. Minivans actually make good tow vehicles as long as you stay within their capabilities, as most modern ones have plenty of power and they have a low center of gravity. The big downfall of minivans is their soft rear suspension (for most) as they are designed as people movers, not tow beasts. You can add airbags to help combat the softer springs in the rear, but remember, the bags don't increase your carrying capacity. You still have to be mindful of the tongue weight.
Would a larger SUV be a better towing platform? Certainly, but as long as you stay well within your weight limits, you should be fine although the mountain towing may be an issue. As was mentioned earlier, these year model vans did have a transmission issue. We had an '04 and Honda replaced the transmission with 80K on it and having never towed. Wife was nervous of it after that, so we sold it not long after the replacement, so I don't know how well it did.
Most minivans have payload ratings as good or better than a lot of half ton suv's and pickups. Cooling is the issue more than anything.
As long as cooling was not an issue, they can easily handle small low wall pop-ups. I think our old pop-up was around 1400 gross, and I could lift the tongue by myself.
44,066 PostsLatest Activity: Jul 25, 2018
