Dad12153's avatar
Dad12153
towing poundage//correct??
have a 2004 sierra 1500 w/3.73 diff....5.3l v-8...standard bed...several publications list this to be able to tow 8100 lbs...also know following:
1. gvwr=6200
2. fawr=3600
3. rawr=3886
vehicle weight w/full gas/me in it
4. front axle weight 3080
5. rear axle weight 2040
6. total weight 5120
so, all this means i have a payload,which will include the tongue weight of a TT, to be 1080lbs???(6200-5120) is this correct?? also, seems to me that if the combined axle weight rating is 7486 lbs, why is the gvwr only 6200lbs???
  • You have to understand that the ratings are NOT those of the actual engineer who designed and oversaw the building of the systems, but are the product of the legal department, who makes ALL decisions based on culpability, NOT facts. According to a family member, who is a department head with one of the big 3, everything is derated a minimum of 20-40% by the legal department.
  • Based on the manufacturers information and ratings that is correct.
  • GVW is more than the sum of its parts. To correctly determine how much you can safely load/tow you need to load the vehicle up like your going on a trip and drive across a set of scales. Look on the drivers door post, take the rated GVWR and subtract scaled weight from that. More than likely you will find that your available payload will be around 800 pounds or possible even less.
  • According to your weights you have 1846 lbs of payload left before you go over your rear axle rating.
    You have about 1080 lbs before you go over you GVWR yes..
    I drove a tractor trailer many years. The DOT only cares about axle weights and tire ratings to carry the load..
    Your most important factor when towing is trans temps.. If it has a cooler its probably too small. Install the largest you can fit IMO.
    What else are you going to put in the truck and what are you thinking about towing?
