What is the industry standard for a dry weight figure ? Is there one ?
To really establish a real number , each unit has to be weighed as it leaves the factory to you. That's a dry weight and it will include the options that you wanted. Every unit of the same model is going to be a little different, weight wise.
In order to test things out and prep it for you, the dealer adds some water, propane and a battery, ( usually a grp 24 @ 46 lbs. ) .
When you show up to pick it up , you really add things up when you add your personal stuff and your hitch, bars and sway control.
A portion of it all gets transferred to the TV. It's at that point, when you are all loaded up for a trip is when you get shocked at the scales.
*******The only way to know a weight is to weigh it.********** don't read brochures and websites for weights and absorbing those numbers as facts.
