MFOX
Dec 09, 2013Explorer
Towing question
Hi! We are looking for a new truck because our 12 year old suburban is slowly dying. We are looking at a Ford Explorer 8 cyclinder with a max. tow rating of 7000. We are also looking at a KZ Fronti...
BarneyS wrote:RinconVTR wrote:
There's nothing but******for replies in this thread so far.
NO ONE pointed out you stated the trailer is 7000lbs GROSS, meaning it will likely NEVER come near that number unless you carelessly overload it.
GVWR is NOT the number to shop and match TV's with. Sure you can, there is no harm, but more often than not you will buy a TV that is far more than you ever required.
In your case, matching the TV max towing with the max the trailer should ever be, should be fine. HOWEVER, the Explorer is typically known as a Mid-Size SUV. Just because it can tow 7000lbs, doesnt mean it will do so comfortably. You'll want to make the the actual loaded weight isnt really that close to the max ratings, strictly for comfort.
I towed with a 2012 Honda Pilot nearly maxed out, and it did so very well, but I felt it wasnt comfortable enough to travel entire days at a time, as we changed our plans to start national travel with the TT. So we bought a 2010 Sequoia. There isnt a whole lot different, other than I dont feel the trailer as much, and day long drives wont wear on the driver as much.
Your first sentance is as much **** as you seem to think everyone else's is. Your next two paragraph sentences are just about as bad. You only start to make sense with your last two paragraphs.
Barney
