You say a 32' travel trailer but don't say either the weight or make model etc.
Check the yellow sticker inside your truck door for the towing capacity info, as well as checking the info for the trailer. A 32' trailer could be a 27' box with 32' total length or a 32' box. Weight range can be anywhere from 6,500 to 12,000 depending on model.
Ram 1500's can be pretty light on their towing capabilities so try to find your capacities. If you saved the window sticker it should tell you what, if any tow packages you have.
A quick google search found this.
2013 Ram
