Hello my fellow campers! New to the forum and I figured someone here could help me with a concern I have. Last fall we had upgraded our camper, we went from a hybrid to a 32 foot travel trailer. While...
If you were at 5K there is a possibility you may have been about a quart low. For all around driving, no big deal, but towing will cause excessive heat. Less oil absorbs heat faster, therefore whatever oil cooler you have must remove heat from a higher temperature oil. Not sure if that was the issue but 248 degrees is about 30-40 degrees high.
