forjonny wrote:
Huntindog wrote:
rjstractor wrote:
I did a little bit of research on the Sorento and could not find what the Gross Combined Weight Rating (GCWR) is for that vehicle. However, I did find that the minimum payload for a loaded AWD model is about 1300 pounds, which isn't bad and actually better than some full size pickups. If your trailer's gross weight is 3500 pounds than it will likely be a good match for the AWD Sorento as long as you watch your payload. The trailer's hitch weight will add 500-600 pounds to what the vehicle carries. A good weight distribution hitch will be necessary to spread that weight between the front and rear of your tow vehicle.
To answer one of your questions, generally speaking, the higher a vehicle's tow rating, the better it will handle a trailer of a given weight. Any time you approach or exceed tow capacity, performance, handling and the durability of the vehicle suffer.
Does the Sorento have a frame? Or is it a unibody?
Gotta be careful with unibodies. WD isn't always a good thing with them.
Check with the manufacturer on this.
With the larger motor on the Sorento the towing capacity goes up to 5000 Lbs. I don't know what you mean by 1300 lbs with 3.3L engine.
This is what it says for the 2018 and 2019:
Steel Unibody (Iso-Structure Construction)
Whatever that means. And what is a WD?
I haven't bought the vehicle yet. That will be in November that I will purchase this vehicle. Don't know what year I will get though. All depends on financing from the company.
3.3L V6 Gasoline Direct Injection (GDI) is the engine that I will get and that is the LX V6 model which the towing capacity with the AWD is 5000 lbs. The travel trailer is 3500 Lbs.
