fla-gypsy wrote:
BarneyS wrote:
If he had a Hensley hitch then it was not installed properly. The hitch WILL NOT allow a trailer to throw any tow vehicle all over the road when being towed. The only way that could happen is if the struts between the hitch head and the frame brackets were not tightened down properly or even not installed. You could even tow without any spring bars attached and it would still not allow the trailer to throw the tow vehicle around.
Barney
Perhaps even the Hensley is no match for a bad set up?
Given the information in the OP, not in this case - in my opinion.
Barney
