I've always run LT tires so the tires aren't an issue. That said, I've set speed based on engine performance taking it up to where real time gas mileage started it's rapid decline, then back off a bit. Depending on conditions that was generally somewhere between 60-68. Of course in the states with lower speed limits Of course if the speed limit is lower, that dictates your speed.
