COGirl's avatar
COGirl
Towing Trailer with a 4Runner
Hi-
I currently own a 2016 Toyota 4Runner. My husband and I are looking to purchase a travel trailer this spring. Our 4Runner has a towing capacity of 5,000 lbs. My question is, has anyone towed a trailer behind a 4Runner before? If so, what length and weight should we aim for? We live in CO so the air is thin. Should we factor that in when we look at the towing capacity of our vehicle? Also, what other factors should we consider when purchasing a trailer?
Thanks!
  • Go with a pop-up I think you will have more room, they can go 24' long with a slide out kitchen.
    We came from Colorado grew up there for 40 years. We did tent camping mostly in the winter, NP so the pop-up should not be an issue.
  • We tow a small trailer with a Tacoma -- a little beefier than a 4Runner, but not much. (See links in signature below for more info.) Bottom line -- if you stay on the small side, you should be ok. (Of course, since you are in Colorado and you live in Camping Heaven, why not spring for a monster truck so you can tow anything, anywhere?) ;)
  • watch your payload. towing capacity will not be your limiting factor. If it were me id be looking at a larger popup
  • While many tow at the 5000# limit and above it isn't a good idea. Look for a TT that will weigh around 4000# fully loaded and I think you will be much happier out there in CO.
  • Welcome to the Forum.
    With the right hitch setup you could pull a small trailer up to about 20 feet long with an empty weight of 3,000 to 3,500 pound. Anything over that will be a challenge. It's all about cargo capacity. Check you door sticker for the weight you can haul in the vehicle. You will have to find a trailer with a tongue weight of 500 pounds or less.
    There will be several on here that tell you it is unsafe to tow anything other than a small pop-up with a Forerunner. I just got out of a Forerunner and they are great vehicles.
