rvshrinker's avatar
rvshrinker
Explorer III
Jan 07, 2018
Towing travel trailer in the snow
I want to take my trailer skiing. I wouldn’t go in a storm, but I need to be prepared in case the roads are icy or we get a little snow.
According to my state regs, I need chains for both the TV and the trailer, but it’s not more specific than that.
- for the trailer, I read about “Drag chains”. What are those, how are those different from “tire chains”?
- I have a two axle trailer. Do I need 2 tires chained, or 4? If 2, I assume I chain the axle with brakes. If both have brakes, do I chain the rear or front axle?
- For the TV, which is a 4x4 full ton truck, do I chain just the 2 rear wheels (drive wheels) assuming I’m only using those 2 if I’m not in 4x4? Although, naturally it would make sense to be in 4x4 if I’m towing in snow.
- Other than “go really slow, be really careful, leave lots of room for braking” and “I’d stay home if I were you,” do you have any suggestions or tips?
Thanks!
  • Drag chains are conventional tire chains that go on a farthest back braking axle to "drag" the trailer to slow it down rather coming around and hitting TV. You must have one on each side of trailer.
    You do not have to install chains on four wheel drive unless signs say to. You must carry chains.
    WA winter driving
    Note that in WA vehicles over 10,000 must adhere
    WA chain placement
    OR chain placement
