subcamper
Jul 04, 2013Explorer II
myredracer wrote:
If anyone says towing with full tanks is no problem, I say that they are playing with fire.
The first thing you should do if you want to do this is go weigh your trailer at a scale and see what the actual wet/loaded weight is and then compare that to your GVWR. Then, and only then, decide if you want to tow your trailer and exceed the GVWR.
Many trailers weigh too close to the GVWR when loaded for camping. If we were to travel with a tank full of fresh water, we would be overloaded. If we were to travel with all 4 tanks full, we'd be more than 1,000 lbs over the GVWR. I am not going to do it. If you really want to and your trailer is still under warranty, I would see if your dealer will give you something in writing that will cover a crack or failure if you tow with one or more full tanks. I doubt they will do it. The first thing Lippert will try and say is that you overloaded your frame and walk away from it.
For those that insist that trailers should be and are built to handle the weight of water, then you would do good to start reading all the posts you can find on the various RV forums out there about owners who have had cracked frames, failed welds and broken tank support straps from overloading their trailers. It happens a lot more than people realize. Frames these days are being built on the thin edge of barely being able to support just the UVW. Frames typically aren't even I-beams anymore, they're 3 pieces of sheet metal welded together to look like an I-beam and they flex like crazy. If you knew what your frame was really like, I doubt that anyone would think it was no problem.
x2
I never tow with full tanks, on about 5 gallons in the FW tank if we need to stop on the way and use the bathroom.
When out TT was 2 years old, I had to take the underbelly cover off for a mod I was making (adding macerator pump). I was shocked at the mounting of the grey and black tanks. They had angle iron pieces that run along their length at each side and then a flat piece is welded to the angle iron end so it can bolt to the frame crossmembers. The angle iron supports were fabricated about 3/8" too short so they didn't butt the crossmember. Which means the self-threading screws they used to attach it to the crossmember were no longer in shear (screws would have to break across them to fail)but were in a pull-out mode (all the screws had to do was pull out of the hole) which is far weaker. The angle support had dropped about 3/8" at the end and was in the process of pulling out the screws. If I had travelled with full tanks, it almost certainly would have failed. I repaired them with a spacer and through bolts.
If you really want to travel with full tanks, have a trusted friend or mechanic-type who knows what they are doing inspect the tank mounting to verify everything is ok.
Steve
