bpounds
Mar 28, 2017Nomad
If you are only getting the pull to the right when towing, I suspect you need to adjust the weight distribution hitch adjustment. You are probably lifting weight off the front axle. As well as check all the front axle steering components.
I do not believe any issue with the trailer axles will cause this. Your trailer can only pull on your truck in the center on the ball.
