I have a 29TE travel trailer, it's 6100 lbs empty, 7700 lbs loaded, my truck is a 2wd 5.3 V8 with the HD transmission cooling package, and towing package. It's a sylverado 1/2 ton 2010 crew cab, the d...
You can more than likely tow that TT, but I don't think you will be happy with the results. That's a pretty heavy trailer for that truck, it will put you near the top of all your ratings. Your truck might be rated for 10,500 but I have my doubts. Try it out....I'm guessing after a few trips you will be looking to upgrade to a heavier truck with a stronger powertrain.
