BenK
Sep 04, 2013Explorer
Op...you are asking manual tranny questions and your TV has an automatic...as
KD4UPL says, let it do the shifting...
Yes, use the Tow/Haul button and let the 'automatic' do the shifting. The T/H
button tells the automatic tranny's computer that you either are hauling a load
or towing something
Another question is what loading does the TV have? If loaded to it's GVWR, then
of course it will be sloooooooooow...as the TV will be **_AT_** its maximum
weight without the trailer
Trailer tires (ST class) are only rated for 65MPH MAXIMUM.
Assume the glove box manual says to put the shifter lever into a gear...another
assumption is 'D' while using the T/H button...so if someone who has one and
can read their glove box manual or the OP read it if that company truck still
has it
or towing something
has it
44,056 PostsLatest Activity: Dec 27, 2025
