mhsmith
Jan 02, 2014Explorer
I had a '98 1500 burb and towed our 7800lb. trailer with it. Did ok, but I was at the max for the truck and at 189,000 miles, it was time for a new one. It should do just fine for what you are pulling. Like others before...NO OVERDRIVE when towing if it is a 4-speed tranny. I found out the hard way and ended up replacing mine around 124,000 miles. It doesn't have enough RPM on the trans pump to move the fluid to keep the fluid cool when towing in OD.
44,056 PostsLatest Activity: Jan 12, 2020
