bailer6334
Dec 11, 2016Explorer
All the above is good advice. As I have a 2015 DD with the eight speed can't speak to the OD lockout. Check your owners manual on that. Also when you purchase check the tire speed ratings on the tires and do not exceed the ratings. Also if tires are older than 4 years plan on replacing them ASAP. ST tires are only good for about 3-5 years or 10-12,000 miles. If they need to be replaced upgrade to D or E rating if possible.
Also as a new owner do a through Pre Delivery Inspection (PDI) to find things to be fixed prior to purchase. Usually takes about 2-3 hours. A lot of inspection guidance on this and the internet. Take your time and do your due diligence.
Good Luck
Good Luck
