MFL
Oct 22, 2016Nomad II
You need to weigh your truck with fuel, gear, passengers to get actual numbers. As most of the FW pin wt will be on your rear axle, you need to stay under RAWR, and max tire.
A 14K actual loaded weight FW, would max out your 2500. Like mentioned, 20 percent would be 2800 lbs, plus 200 for hitch. After weighing rear axle do you have 3000 lbs left before going over RAWR?
Jerry
Jerry
