Denali_Newbie
Jul 08, 2019Explorer
Lol..true that! Just watched a you tube heads up between Denali and Navigator from fast lane truck called the Ike gauntlet test. Real cool. Had some towing expert that balanced the 7000lb horse trailer to have 700 lbs on the tounge. They had WD hitch on it and both vehicles were stable and power left in the pedal. I'm sure I will pull a 4200 lb dry weight after loading up with usual suspects no problem. Just a matter of balancing the weight out properly now and setting up the WD hitch and anti sway properly. And I completely understand payload now (which they only added to by about 600 lbs above standard 150 lb driver allowance plus the 700 lb TW. So I will have a higher payload with my gear. Will get those numbers posted when I get home.
