Bionic Man wrote:
Going away from the MPG love fest, and back to the original topic.
Isn't that within the Touareg's tow ratings (even if on the high side)?
In regards to the motor, I would ask the question of what is more important; output or displacement? The 3.0 V6 diesels have very similar output to the vaunted 2nd Gen 5.9 CTD and the 7.3 Powerstroke. I hear very few people saying that those motors aren't powerful enough to use for towing, but put those same HP and torque numbers into a modern 3.0 diesel with twice the gearing, and they are suddenly inadequate. That doesn't make sense to me.
Personally I would not want to be towing a 7000 pound RV with that size of a tow vehicle, but if it is within the manufacture ratings, their engineers/marketing people think it is acceptable. They are the ones that will have to budget to fix it if it breaks during the warranty period. I would hope they know more than I do about the whole package.
Think about the load bearing surfaces for making that torque and HP from a 444 Ci 7.3 L diesel, how much piston surface, block bore surface, bearing surface, the size of the wrist pins and connecting rods, etc, to get the same horsepower... that's a mere 181 cubic inch, 3.0 liter motor. Ask a mechanical engineer to do the stress loads on all the parts for the amount of work done. You have to run 2.5x the amount of fuel and air or more, due to VW using the turbochargers boost to air cool the motor also, volume wise to a 3.0L to a 7.3 motor.
The little motor, is working much, much harder, with much less material, for the same amount of work being done. Guess which motor will wear out quicker and fail sooner?
My 3.0 will pull 8th gear on flat ground at 57 to 58 MPH at 1600 rpms with trailer in tow, no problem. Add in a slight grade and it will drop to 7th or 6th gear right quick. Someone getting 9 MPG at 65 MPH is burning 7 gallons of fuel per hour in a 3 liter motor. Count the calories and amount of heat to be lost doing that.
