Learjet
Sep 30, 2013Explorer
unless you need lower than first, which isn't what you are asking about, 4:30 the engine will turn @ 200 rpm more per gear. overall gearing is @ the same if you run 1 gear lower than a 4:30. So your 3rd would be 4th in a truck with 4:30, 2nd equal to 3rd...etc.
So, I don't think you will see the difference you expect.
Are you over at FTE? seem like the same question over there?
44,066 PostsLatest Activity: Oct 04, 2013
