Terryallan
May 23, 2017Explorer II
Doublemks wrote:
Does it matter that we have the air ride(air bag) suspension?
There are instructions on how to setup a Expe with air ride. It is in the book, but is something like this. tow the TT to a level area. Raise the tongue OFF the ball. start the Expe, and let it level itself. After it does. Turn off the air ride before it can settle back down. Then measure the distance from the front bumper to the ground, and the rear as well. Drop the tongue back on the ball. Measure again. Attach spring bars, and adjust until you have returned at least 1/2 of the distance raised back to the front. Example. If the front raised 1", you want to adjust until it is only up 1/2" or less.
And the rear should be no higher hooked up than it was unhooked. Yes a WDh "CAN" raise the rear higher than it started out to be. but in general. IF you get the front right, the rear will take care of itself.
Once you are done. Turn the air ride back on, and you won't have to mess with it again.
