hommer638 wrote:
Thanks to all that replied. I knew that I would be close for weight.
But it's just the wife and me, no kids, and I was planning in taking out all the rear seats in the van when going on a trip. Even then I think weight wise I will be too close to the limit. I do not like the idea of going on a long trip thinking of what might happen on the road.
So I think we will be shopping for a pickup ether full or mid size.
Probably a good plan. Here are some things to keep in mind when truck shopping.
There will be a tire and loading sticker (on drivers door or door post) that shows a max occupant / cargo weight rating (AKA payload). That number is the trucks capacity to carry things. It gets used up by weight of aftermarket accessories (bed caps / liners, undercoating, step bars, floor mats, etc), people, pets, cargo, hitch equipment, and loaded trailer tongue weight.
Loaded trailer tongue weight will be about 12 - 13 percent of total trailer weight.
Your trailer is about 2900 lbs empty. It will be 36 - 3800 lbs when ready to camp. Your loaded tongue weight will be 475 +/- 25 lbs.
You'll need to find a tow vehicle with enough payload to carry everything listed above, plus your family, have a little wiggle room for unexpected weight, and enough tow capacity left to tow at least the gross weight (about 3950 lbs) of your trailer. That could be a bigger van, an SUV, or pickup truck. Maybe find a tow vehicle that is big enough to handle your next (bigger) trailer.
Trailer tongue weight is not a constant number. It goes up and down during every trip. If you have holding tanks that are located in front of the trailer axles, they will add more weight to your tongue weight. If they are behind the axles, they will take weight off the tongue.
The added weight of accessories, people, pets, and cargo, not only eats up available payload, it also reduces the vehicle's max tow capacity, pound for pound.
Hitch receivers have weight ratings (with and without weight distribution) of their own.
Tow vehicles are not all created equal. You may find two trucks, sitting side by side, same year/make/model, with different payload and tow capacities.
Note: The closer you get to max weight on either payload or tow capacity, the more unpleasant your towing experience will be.
