Technical specs of our old 625D
Length (closed) (in/closed) (ft/closed) (mm/closed) (m) 215 / 17.9 / 5461 / 5.5
Width (in/mm) 85 / 2159
Interior Height (in/mm) 78 / 1981.2
Length (ft/ft) 23
Length (ft/in) 6
Height (closed) (in/closed) (ft/closed) (mm/closed) (m) 61 / 5.1 / 1549.4 / 1.5
Dry Weight (lbs/kg) 2473 / 1121.8
Options Added: roof air, batteries, propane, furnace new dry wt: 3000lbs
Payload Capacity (lbs/kgs) 760 / 344.7 decreased due to options: 252lbs
GVWR (lbs/kgs) 3252 / 1475.1 Dealt with flexing frame, doors opening, and other crap.
Hitch Weight (lbs/kgs) 292 / 132.5 nope 400lbs......after options
Capacities Standard
Number Of Fresh Water Holding Tanks 1
Total Fresh Water Tank Capacity (gal/l) 20 .....not enough for a weekend.....
