JALLEN4 wrote:
SweetLou wrote:
pauldub wrote:
I'm not sure how you're going to drive I-15 from California to Washington, maybe you mean I-5. You'll have to go over the mountains in northern California on I-5. I'd be a bit concerned after reading the owner's manual for your 2019 Subie.
Here's one quote: SUBARU warranties do not apply to
vehicle damage or malfunction caused by
trailer towing.
Here's another quote that isn't encouraging: When towing a trailer on a long uphill grade continuously for over 5 miles (8 km) with an outside temperature of 104F (40C) or above Maximum total trailer weight 1,350 lbs (612 kg)
I didn't think I needed to explain how you get to Washington from the I-15 but just to let you know it connects with the I-90. I am leasing the car so if the trans takes a ****, its theirs not mine. It came with a tow package so it must mean you can tow with it under 2700lbs. As long as you can prove that you are under that, then the language means nothing. I think I'm safe at 1100 lbs
I don't know a thing about the towing question but I know a lot about leases. If the warranty repair is rejected, they will hold you responsible and they will collect.
Key phrase if its rejected. I think they need to prove that a CVT transmission was overly used for towing, or that the day you towed it was above 104 degrees. I can make my case very well. I plan to tow with it 4x a year 1500 miles each way with a light load. No issues
