blofgren wrote:
Thom02099 wrote:
travelnman wrote:
Anyone tow with a Tahoe vs Suburban? Considering buying a 2014 Tahoe in beautiful shape just like granny used to drive. Wonder if the shorter wheel base will give me trouble with sway. With the suburban I have none at all. The suburban has the 3.73 axel with the 5.3 engine and handles the job but could use a little more power which the Tahoe has.
It also has the 3.42 axel, 5.3 engine, newer six speed transmission. My suburban has the older four speed trany. The TT is a Keystone Spingdale 2008 coming in at 6,200 dry. Both vehicles have all the heavy duty cooling, larger radiators, etc. Any experience with a Tahoe towing would be helpful before I spend my life savings on one.
Not quite the same as what you're looking at, but here's a real world perspective. I have a 2003 Tahoe (all the tow package add ons) that I used to tow a 2007 Keystone Outback 25RSS which weighed in at ~6000lbs (scale weight) with everything on board including water. Slightly lighter weight trailer than what you're considering, weight limit on the Tahoe is 7400lbs and the GCWR was around 13600 IIRC, and I was at 11,800lbs scale weight with everything on board in the Tahoe, sometimes including an 80lb fur friend.
Anyway, the combo was fine...for flat lands. towing in the mountains of Colorado, it would go, but it would be slow. I'm talking 25MPH slow in 2nd gear on a grade similar to the Ike Gauntlet. And on most concrete interstates, there was a lot of porpoising, probably due to the shorter wheelbase. No problem at all with sway, with a good WDH setup, which I have.
Granted, the newer Tahoes have a higher weight capacity, but it's also a heavier vehicle than my '03, and the trailer you're considering is also heavier. If you're never going to tow in mountains, it's a fine combo if you stay off concrete road surfaces.
The Tahoe is a fine vehicle and I still have it. Just don't use it for towing. If you've got a Suburban, you'll appreciate the longer wheelbase and hopefully greater payload capacity. MY solution was to go to a 2007 GMC Sierra Classic 3500 HD dually and a slightly heavier trailer.
I'm a bit surprised to read this as our 2001 Yukon 4x4 with the 5.3L and 3.73 gears tows our 4500 lb boat just fine with lots of power. I'm wondering if the airflow effects on the travel trailer was causing the big difference because I sure wouldn't have guessed that 1500 lbs would make that much of a difference.
The Ike Gauntlet gains 2000 feet in elevation at just over 8 miles and has a maximum of 7% grade. Given that and the trailer frontal area, I'm sure the combo is what caused the Tahoe to struggle. One particular road I travel, the South St. Vrain Canyon, has a similar elevation gain for where I go, with some 10-12% grades. The Tahoe did not like this road at all. The Sierra is "meh" towing it.
