bikendan wrote:
blofgren wrote:
Would the coil spring suspension on the Tahoe possibly make it handle worse than the leaf springs on the 1/2 ton pickup? I do notice our Yukon is a bit "squishy" at times because of the soft suspension designed for the good ride. Ours has the Autoride as well which likely doesn't help much lol.
Not aware that Tahoes have coil springs. Thought they had leaf springs.
blt2ski wrote:
I have yet to see a Tahoe with coils on rear.
The GM full size SUV's have been running coil springs on the rear since the 2000MY.
blofgren, hard to answer your question. How was the spring designed? A big huge thick wire that makes one coil to carry half of the rated axle rating? One big thick leaf with super stiff material? Or was it multiple leafs with a less stiff material?
In my opinion, the GM SUV's will handle the weight they are rated for. Ride quality will start to degrade considerably the more you exceed those weights.
