HaulinBass02
Aug 06, 2017Explorer
The ball joints are new, it also has a new trackbar in front with new bushings, new adjustable shocks. Given the tire size, I'm THINKING it has a spring swap in front at the least. Not quite sure about the rear yet, once I get it I will dig further into it. It does have a factory sway bar on the rear, so I will probably upgrade it to a larger one and replace the bushings. It drives solid so that is a plus.
I've been planning on a Reese Dual cam upgrade anyway with my current rig, I know that will help as well.
Is the airbag setup a necessity or do you feel if I had the f-250 or modified f-350 springs on it that they would suffice? Our TT hasn't been weighed but comes in somewhere near 8k but a larger TT is probably in the future too....
44,064 PostsLatest Activity: Apr 12, 2026
