coolmom42's avatar
coolmom42
Explorer II
Sep 14, 2016
Towing with an Explorer, Highlander or 4Runner-experiences?
I am seriously considering a Lance 1475 TT, dry wt 2495, gross 3700. I want to tow with a SUV, and have a fondness for Toyotas. (Ford Explorer is also in the running.) A Highlander, 4Runner, or Explorer equipped with tow package has a tow rating of 5000 lb & hitch rating of 500.
I probably would never load a trailer to the max as I travel pretty light. My biggest concern with any of these vehicles is the weight distribution. The Highlander is on a uni-body type frame, the 4Runner is on a truck-type frame, and I'm not sure about the Explorer. There is a lot of skepticism out there regarding the use of a weight distribution system with the uni-body frame.
I did see several small trailers being towed with Highlanders on the Natchez Trace Parkway back in the spring. However, that's not exactly a demanding drive. My travels are more likely to be in East Tennessee, which has some steep climbs and long grades.
I will probably go with an Andersen hitch for WD & sway control.
Just wondering if anyone has any experience towing with any of these vehicles and what input you might have.
