LarryJM
Jun 16, 2017Explorer II
Terryallan wrote:
?Sounds like it is doing a good job. No problems, EXCEPT as mentioned above. 99 percent of TT tires are rated to 65mph. IF you are running 70+ you are going too fast. Slow it down, and relax. No one will run over you.
Excellent point and compromising a tire's reliability is not necessarily a cumulative thing ... IMO it's sort of like cracking a glass, it only takes one time to crack it and then you've done the damage immediately. In view of the potential damage from a blowout vs the total cost of new tires if it were me I would be replacing all those tires ASAP. I personally just would no longer trust them to any longer. Of course I'm also the one that if I do have a flat on a tire, I consider the other tire on that side also no good (i.e. compromised reliability wise) and I replace tires in pairs.
Larry
