spud1957
Oct 11, 2014Explorer
boobie41 wrote:
thinking of buying a solitude 320x 5th wheel, only have a ford f250 gas, 2015 pu, willthis do the job?
If you have 4:30 gears, yes. With 3:73s you will be pretty close or over Ford's tow rating of around 12.5K for 3:73 gears. I tow around 10K with 3:73s. Wouldn't want to go heavier unless I did a gear swap.
Pin weight will be something to consider as well. Check your available payload/capacity tire label on your driver's door post.
S
44,056 PostsLatest Activity: May 04, 2014
