CharlesinGA
Apr 18, 2020Explorer
Go to the dealer parts department and give them the VIN number and ask them to print you off a build sheet. This will give you the rear axle ratio but will also give you all the options and option codes.
Easier than that however is to simply open your glove box and look at the sticker in it. It will give the VIN, the trans and code, the axle ratio and ring gear size and code and primary and secondary paint codes.
Did it have a factory tow package? The build sheet will tell you.
How to identify factory vs dealer installed Mopar receiver.
Charles
Charles
