jsmith_15's avatar
jsmith_15
Towing with RAM 1500
I have a 2016 RAM 1500 v8 5.7 8hp70 transmission Crew cab with a max pay load of 1520/GVWR 6900. It has a max towing weight of 8040lbs and GCWR is 13,800. The trailer I am interested in has a dry weight of 5385, dry hitch weight of 619 and GVWR is 7619lbs. My rear axle ratio is only 3.21. I would be traveling with tanks empty (unless filling is better for stabilization) through fairly flat areas, no steep hills. I need advice on whether this is too much trailer for this vehicle. I have no experience towing...just sold my Class C yesterday. I'm getting mixed signals on whether this is something I can tow.
  • Just saying, I was shocked when the scales showed that my F-150 only had about 600 pounds of payload left when I was packed and ready to hitch up. I "Figured" that I had close to 1,000 available.
  • your hitch weight will likely be in the 750-900 lb range. If you have a box cover or running boards, spray in bed liner, that kind of stuff, it all takes away from your 1350. you will be right at the limit but I had a 2012 Ram and it handled our trailers well, we were over weight on both however.
  • That is the weakness in these Rams, they will pull a lot but carry little. My 2014 Ram Sport is almost identical to your, 3:21 rear/8 speed auto/hemi/#1350 capacity. I tow a 4300# fiberglass 21' trailer about 8,000/miles a year and average 13-14 mpg in tow mode. My 2009 Ram with 5 speed and same trailer only averaged 12 mpg. My tongue weight is 500#. Check your t/w capacity, you may have to use a w/d set up to transfer some weight off your to your front.
  • BTW, I also recommend air bags for the rear spring set up to keep the truck level.
  • A trailer with a 5400 lbs dry weight will be about 6900 lbs loaded and ready to go. That puts the tongue weight at somewhere around 825 lbs. So if you subtract the 825 from the 1351 "payload" number you stated earlier, that leaves you with about 525 lbs for you, the wife, the kids, the dog, the hitch, and anything else you "load" in the truck to take with you. That's how the "payload - not to exceed" math works.
  • Math is great but scales are better. It is easy to overlook the weight of toolboxes, extra water, generator, gas can, topper, coolers, hitch, accessories, etc. It may shock you to find out how little you have left. Or maybe I am the only one who thinks they need all that stuff?
  • You might try a set of these also I installed these on my 2014 Crew Cab 5.7 Hemi.
    They made quite a bit of difference on rear end sag and the ride is not any different then it was stock.
    Tuff Springs
  • Thanks for the input, TxTwoSome. I've been leaning toward those too. Was also considering their 1211s.
  • That 3:21 rear gear is the real enemy here. Just take your time & don't try to win any races & you'll be just fine. I had the same basic setup as you only I had the 3:92 rear gear & it did great. Make sure you are always using TOW/HAUL mode when towing, even at highway speeds to minimize transmission shifting up & down which causes heat buildup in it.
