otrfun
Jan 01, 2015Explorer II
IDman wrote:It's important to keep in mind the Ram 2500 5.7 has 900-1000 lbs. less payload than the same Ram 2500 with a 6.4. Many will argue this is just on paper since the rear GAWR is the same for the 5.7 & 6.4 (fwiw, GVWR is exactly 1000 lbs. less for the 5.7--confusing to say the least). Regardless, that's a BIG deal if you tow.
We are going from diesel back to gasser and I will stick with a Ram 2500. We tow all over the West which, of course, means lots of mountains to climb so I would like the power and payload of the 6.4.
On the other hand, the truck will be my daily driver so I would lean toward the 5.7 for mpg. As I shop, research, and listen to others, I am realizing the best of each engine, BUT I am not hearing from others that tow in the mountains.
I would appreciate hearing from those who tow with either engine, in the 2500.
Please don't turn this into a brand war.
Thanks in advance and Happy New Year!
If you tow, and factor in the fact the 6.4 has MDS (better MPG), more torque/hp, and almost a 1000 lbs. more payload, IMO $1300-$1400 is a small price to pay for all this capability.
Good luck and Happy New Years!
