AntonB
Feb 08, 2014Explorer
Thanks E&J push'n wind, the sticker inside the truck says GVWR 7900lb & the manufacturer GCWR is 15000lb. So I am confused then, I have a tow rating of 8750lbs, if you add the 7900lb and 8750 lb together you get 16650 as a GCVR, that is 1650lb over the GCVR that the manufacturer has published. So am I really only able to tow 7100lbs?
44,071 PostsLatest Activity: Aug 30, 2026
