Ron_Gratz
Feb 20, 2014Explorer
DiskDoctr wrote:Are you telling us that your 80% comfort factor is based on physics?
'Little relevance...' Really? how does gravity, wind, levers, and all that good stuff work in 'your world'??? It still pulls Down, doesn't it? Or does 'Gravity 1.2' work in some other direction?---
If so, can you tell us how physics was used to determine the 80% comfort factor, and what is the 80% applied to -- GCWR, GCWR minus loaded TV GVW, "Maximum Trailer Weight", "Maximum Trailer Weight" minus TV payload, etc, etc.
Then, can you please tell us how your "gravity, wind, levers, and all that good stuff" gives a better maximum trailer weight than the values determined by TV manufacturers.
I'm just trying to understand what your 80% value is based on and what you apply it to. For example:
DiskDoctr wrote:By my math --
In any case, I tow regularly with my 4Runner V8 Limited (rated @ 7k tow) at about 6000-6500 lbs with a full cargo area in SUV. A bit of lugging on the steep mountains, but never had a handling or braking issue.
80% of 7000# is 5600# and
6000-6500# is 86-93% of 7000#.
Does that mean it's really okay to tow at 93% of the rated towing capacity? How about 100%?
Ron
44,070 PostsLatest Activity: Sep 18, 2026
