boosTT
Mar 20, 2017Explorer
katoom400 wrote:
ok, so I never did anything for my RZR hauling needs. I now need to get something setup before Memorial day.
I know that the Torklift will be the strongest way to go but at $1500, it's about 3X the cost of going with the Reese Titan 2.5" hitch with 24" extension.
From what I can see the 24" extension is rated for 8000lb with WDH which is within my trailer rating of 6000lbs dry ~7000lbs wet
Curt also has a similar setup with similar specs for just over $400 total
since I will only use this setup 1-2 times a year I prefer to save a grand and go with the titan, unless there are safety concerns with this setup? then by all means my only option is the Torklift.
How much distance do you need? The 18" link I posted should give you enough leave the tailgate down without a weight reduction and its $130.
44,068 PostsLatest Activity: Jun 17, 2026
