DCinSJ's avatar
DCinSJ
Towing with Touareg or Cayenne
My current tow vehicle is a Suburban. I now have to replace my car with a small SUV. Getting one with a higher towing capacity (relative to other small SUVs) would enable me to get rid of my Suburban. However, I'm concerned about towing at near the stated capacity. How do the Touareg and/or Cayenne (stated capacity 7716 lbs) do towing 7000 pounds? How about up and down hills (i.e. - Sacramento to Tahoe)?
  • Power shouldn't be a problem. The 3.0 TDI used in the Toureg has nearly identical specs to the VM Motori used in the new Ram which has a higher tow rating.
  • I would agree with bikendan with regards to the short wheelbase. Short SUVs and long TTs don't mix particularly well. Short wheelbased vehicles can not handle the sway of a longer heavier trailer. If you don't already have a very good sway control system I would suggest that be your number one priority if you do make the switch to an SUV. Maybe something like the Husky Centerline system that does not need adjustment.
  • i think you need to look at tongue capacity AND payload amount, not just how much it's rated to tow.
    there's way more to consider, than just towing capacity, especially with a short wheelbase SUV.
